2004 Sebring Sedan Power Windows Not Working
Old Apr 6, 2011 | 07:35 PM
get a wire diagram and check for the power and grounds at the window switch
Old Apr 6, 2011 | 08:02 PM
Djinn-n-Tonic's Avatar
Nah...NO way.....Too easy, ...and too direct ...and ...Oh My GOD....ITS FREE...
NOPE ..we cant do that....
Truthfully.....I have never...In all the years of doing this, seen a faulty breaker for inop windows....Ive seen bad switches, cut wires in the door, and even a woman who swore that her windows went down by themselves and she couldnt get them up.....Only to find all four of them had busted out...
Didnt the broken glass all over the interior mean anything to her...Perhaps not
So...
Old Apr 6, 2011 | 08:26 PM
Master window switch pin-out
MASTER POWER WINDOW SWITCH - BLUE 12 WAY
CAV CIRCUIT FUNCTION
1 F21 14TN FUSED IGNITION SWITCH OUTPUT (RUN)
2 Q17 14DB/WT (EXCEPT JR27 LATE BUILD) MASTER WINDOW SWITCH LEFT REAR UP
2 Q13 14DB (JR27 LATE BUILD) LEFT REAR WINDOW DRIVER UP
3 Q290 14YL/OR (JR27) MASTER WINDOW SWITCH LEFT REAR DOWN
3 Q27 14RD/BK (JR41) MASTER WINDOW SWITCH LEFT REAR (DOWN)
4 Q18 14GY/BK (EXCEPT JR27 LATE BUILD) MASTER WINDOW SWITCH RIGHT REAR UP
4 Q14 14GY (JR27 LATE BUILD) RIGHT REAR WINDOW DRIVER UP
5 Q1 14YL (JR41) POWER WINDOW SWITCH FEED
6 - -
7 Q11 14LB (JR27) LEFT FRONT WINDOW DRIVER (UP)
7 Q11 16LB (JR41) LEFT FRONT WINDOW DRIVER (UP)
8 Q19 14OR/YL (JR27) MASTER WINDOW SWITCH LEFT FRONT (DOWN)
8 Q21 16WT (JR41) LEFT FRONT WINDOW DRIVER (DOWN)
9 Q32 14LB/OR (JR27) MASTER WINDOW SWITCH RIGHT REAR (DOWN)
9 Q28 14DG/WT (JR41) MASTER WINDOW SWITCH RIGHT REAR (DOWN)
10 Z314 14BK GROUND
11 Q38 14OR/LB (JR27) MASTER WINDOW SWITCH RIGHT FRONT (DOWN)
11 Q26 14VT/WT (JR41) MASTER WINDOW SWITCH RIGHT FRONT (DOWN)
12 Q16 14BR/WT MASTER WINDOW SWITCH RIGHT FRONT (UP)
Old Apr 7, 2011 | 05:54 AM
OGHBEICA8's Avatar
72 in Detroit this Sunday! Enjoy a ride with your top down, DC! Hey, I have a valid Wynn's extended service contract that has never been tapped. I'm sure all power window repairs are covered (less my $100 deductible).
One more quick concern if I may: I had my tires rotated and balanced last week. A couple of days later, I noticed a sound (like rubber squeaking) coming from the front end when I cut the steering wheel to the right from a parked/stopped position. Power steering seems to work OK and the vehicle drives normally. What should my mechanic look for after he fixes the power windows?
Thanks, DC!
Old Apr 7, 2011 | 04:13 PM
  #15
Pretty hard to diagnose a sound via a bulletin board. "rubber squeaking" could be power steering belt, tire on pavement, suspension bushing, who knows? Have your mechanic stand by the corner of the car you think the sound is coming from and demonstrate it for him. Of course, if it's like most mysterious sounds, it'll choose that exact moment to cure itself, as least until you get back home.
Old Apr 12, 2011 | 03:43 PM
  #16
OGHBEICA8's Avatar
Where is the POWER WINDOW MASTER SWITCH located in a 2004 Sebring - and can a driveway mechanic easily replace it? I'm willing to give it a whirl. Thanks for enlightening me!
Old Apr 12, 2011 | 08:19 PM
  #17
Thats just a fancy name for the MAIN switch....On the drivers front door....
Its been a while....And I dont recall off hand, but I think the switch just prys up out of the door panel....
Old Apr 12, 2011 | 09:59 PM
  #18
You need to remove the door trim panel.
Old Apr 13, 2011 | 01:19 PM
  #19
OGHBEICA8's Avatar
UPDATE: It took my mechanic 5 hours to diagnose and fix the problem (he said there was a bad wire running under the hood from the right front to the left front window). Being the nice guy that he is, I was only charged for 3 hours of diagnostic time/labor ($250.00 and change) instead of the actual 5 hours. On the way home, guess what ... the windows died and so did my instrument panel/gauges! He then replaced a fuse inside the vehicle and another under the hood, doubling the amperage on both. One more tidbit of info - the right rear window is permanently "dead". I guess 3 out of 4 ain't bad, huh? As I was leaving, he muttered that Chrysler electronics are nightmares to work on. Worse than any other make in the history of automobiles.
Old Apr 13, 2011 | 10:15 PM
  #20
that's a whole load of BS u had better find out what fuses that dumb **** replaced by putting larger amp fuses in there and put the correct ones back in !!!!!!!!!!!!!!!!!
the whole purpose of a fuse is to stop items on that circuit aka motor,switch,wire,or what ever is on there not to catch fire from a short to ground.
have u ever crossed a battery or let it hit a ground and got a big spark? well same thing.
if U have a 10 amp fuse protecting the system that means the wires and electronics are only suppose to handle up to 10 amps u put a 20 amp fuse in there and by god 20 amps will flow through and then begin to melt wires,circuit boards and who knows what else.
dont ever ever ever go back to that guy and yes that is my final word hehe
5 hours to figure out what was wrong my butt and replaced a wire from under the hood to inside my butt as well replace with larger amp fuse good god.
"Chrysler electronics are nightmares to work on"
this means he does not know **** about electronics.
