2006 Sebring limp mode.
Old Jan 27, 2020 | 10:15 PM
Alex Forde's Avatar
Default 2006 Sebring limp mode.
It's saying there's low power to the tcm. I new the battery was old so I changed it but that didn't make a difference. I checked my grounds and everything was tight. 112k on the bash.
Old Jan 28, 2020 | 03:16 PM
What exactly are the codes retrieved? Are you sure you have them all? Have you checked the simple and obvious things like fluid level and quality? Just because a ground wire is tight doesn't necessarily mean that it's a good ground. There can be corrosion. You might need to loosen the connection, wiggle the connector to break up the corrosion and re-tighten.
Old Jan 28, 2020 | 03:44 PM
Alex Forde's Avatar
P0700 which is for the tranny control system
P1684
P0449
P0882
Old Jan 28, 2020 | 03:59 PM
Alex Forde's Avatar
I did get a new battery on Sunday so there's a code for that. I had a new tranny filter and fluid installed during the summer. And I know about the misfire I have a new coil and wires, I'll be getting the Sparks tomorrow.
Old Jan 28, 2020 | 06:08 PM
The P0700 code is just a general code indicating that the TCM has one or more error codes stored in it. You need a sophisticated code reader to drill down to those codes. The usual parts store code reader will not be able to do that. If you google the P0882 code you can find quite a bit of information about it.
Since the car is able to be driven, you might want to consider taking it to a reputable transmission shop for diagnosis and an opinion. If they say the TCM needs to be replaced, your best bet would probably be to find a source on the internet that exchanges car computers and deal with them.
sawwas72
May 10, 2017 12:20 AM
frisco
Jan 30, 2012 01:11 AM
Mashashin
Jan 6, 2010 10:10 PM
studentmechanic
Aug 26, 2009 10:05 PM
Ben
Sep 19, 2006 07:44 AM
