2008 Sebring Electronic Throttle Control issues
Old Aug 13, 2013 | 03:11 PM
Sean1234's Avatar
Smile 2008 Sebring Electronic Throttle Control issues
Hi. First time posting here.
I have an 08 Sebing Touring, 2.7 L engine. I've had it for a year now and the only problem Ive had is the tire pressure sensor going off constantly. But the other day the car would not start. The electronic throttle control light was on and it wouldn't even turn over. After an hour of checking the engine out, I removed most of the fuses to reset the alarm, and it started again. Now the etc light comes on during the system check, but turns off after 8 seconds or so. Oh and I don't know if this is relevant but when I was unable to start the engine, the trunk wouldn't open with the key or the dash button. I've cleaned out the throttle body, just in case, but there is no issue with it sticking as far as I can tell. I will be changing the air filter today as I found some oil on it coming from a hose connected to the crankcase cover. It wasn't much but I think it could be slowing the air flow. So any ideas as to whether I need to do anything else or just leave it alone?
shirlock1
Nov 29, 2012 03:25 PM
cantonlax8
Jul 12, 2012 11:28 AM
profbob
Nov 4, 2010 07:32 AM
azzwoopa05
May 10, 2007 08:37 AM
Imperial90
Feb 6, 2006 05:10 PM
