2011 Chrysler 200: Heater / AC system
Old Sep 1, 2024 | 03:23 PM
JoeyT's Avatar
Default 2011 Chrysler 200: Heater / AC system
Hi,
for teh last few months, some times, when starting up my car, the fan system (whether AC or Heat), does not come on right away. Usually, I will drive for a few miles, and then it suddenly starts to blow air, whether it is in A/C, fan or heat mode. This doesnt happen consistently. At first, It seemed to happen for sure when it rains, and many mornings when condensation has but up. (Very humd in VA where I stay).
I suspect a lose wire because shortly before this started to happen, I was in an accident on the right side door / fender and had the parts fixed. So because the fan eventually comes on and blows air, and seems to happen when its "wet" out this is the first thing I want to check.
I came to look for a wire diagram, but there is so much information on this site, its eluding me. Can anyone point me to the right diagram so I can trace the wires / cables ?
Of course, if someone has experienced this before and has some advice, I am all ears. With winter coming, its time to look in to this more seriously.
Thanks in advance for any help or suggestions.
Joey
Old Sep 2, 2024 | 12:52 AM
passionfruit's Avatar
hey joey, sounds frustrating. i had a similar issue with my old ford focus. might be worth checking the blower motor resistor, it can cause intermittent fan issues. not sure about the wiring diagram though, sorry!
Old Sep 2, 2024 | 08:12 AM
ggoose's Avatar
Suggest posting on '200forums.com'. Contributor there has access to the wiring diagrams
There may be diagnostic codes set in the HVAC control module that should assist in diagnosing the issue. There are reports that some auto parts stores will read the codes from the multitude of computer/control modules. I use the appcar-diagFCA software app and have access to all of the computer/control modules (requires a suitable OBD link to access the modules.
Old Sep 2, 2024 | 11:41 AM
JoeyT's Avatar
Thanks for mentioning the resistor. Will check in to that.
JoeyT's Avatar
Good idea. I will see if there is a shop that can hook it up and see if there is a code.
Thanks for the info!
Kross
Aug 10, 2020 09:32 AM
mike/nav
May 14, 2017 04:47 PM
jamest
Oct 25, 2016 09:24 AM
maddhatter
Apr 10, 2012 10:01 PM
Layce
Oct 18, 2010 09:23 AM
