2012 chrysler 200
Old May 26, 2017 | 02:33 PM
colnorris's Avatar
Default 2012 chrysler 200
in the dash where the mileage shows there's a ( no fuse ) message I've check the iOd fuse under the hood both are good . the key fob will not open or lock the doors and the panic button doesn't work . the locks work fine from the door pannel
Old Jun 5, 2017 | 01:54 PM
Lug's Avatar
Lug
other hits on google have been solved exactly by either replacing or re-seating the IoD, how did you make sure the fuse has no fault ?
Old Jun 6, 2017 | 04:07 AM
colnorris's Avatar
Default testing fuse
I checked it out of the car with a ohm meter and also used a jumper wire to make sure it was connecting on the car still nothing.
Old Jun 6, 2017 | 06:32 AM
Lug's Avatar
Lug
That's a good diagnostic.
Hmm.. not sure here, because these are the "typical" IoD symptoms, but your fuse seems to have no fault.
In your place, I'd try and reset the ECU/PCM , either by clearing codes with a scanner, or having the main car battery (-) terminal off for 30 minutes.
Then see if the "no fuse" prompt returns right away after the battery has been hooked back up, or if it takes a while.
Old Jun 6, 2017 | 11:46 AM
colnorris's Avatar
the scanner ( snap on brand ) shows no codes .. ill try taking the barrety loose for 30 minutes
Old Jun 6, 2017 | 11:52 AM
Lug's Avatar
Lug
another idea is giving a call to your local dealership, they'll tell you the obvious answer, (iod), but maybe they know of another culprit.
They must have dealt with this by now.
Old Jun 7, 2017 | 04:37 AM
colnorris's Avatar
all 3 local deals say is BRING IT IN TO US
Old Jun 7, 2017 | 07:26 AM
Lug's Avatar
Lug
such a helpful bunch really...
Being you're in desperate land at this point, and no other solutions other than IoD replacement show up on Google.
Again, it's just thinking what I'd do in your place, I'd get a hold of another similar fuse and replace it (even though there's nothing wrong with it), and see what happens.
Pretty silly idea, but - you have to consider the options...
BTW, did you manage to unplug the battery for 30 minutes ?
Laredo Scuba Diver
May 19, 2016 05:17 PM
Martyn1953
Jan 13, 2016 08:37 PM
tsousa71
Feb 14, 2015 10:19 AM
Laredo Scuba Diver
Jan 13, 2013 09:59 PM
Laredo Scuba Diver
Nov 21, 2012 09:14 PM
