2013 200 no heat on passenger side
Old Jan 21, 2019 | 06:43 AM
Nathan Turner's Avatar
Default 2013 200 no heat on passenger side
When using any position on my heat the drivers side blows hot like normal but the passenger side is blowing cold air. Any ideas?
Old Jan 21, 2019 | 10:47 AM
REBEL59's Avatar
VERY COMMON symptom for 200/Avengers...plugging up HEATER CORE. Do you have the 2.4 or 3.6 motor? Not that it matters much they are all known for this problem.
Old Jan 21, 2019 | 10:54 AM
Thanks for the response. It’s the 3.6.
Old Jan 24, 2019 | 12:43 AM
UniversalShaman's Avatar
Default What he said
Plugged heater core. Mine is having similar issues, also doesn't want to direct the airflow properly either.
They're talking about a recalibration for this as a fix, perhaps, but come on.
Recalibration? Its a god damn blend door, it directs air flow.
So fed up with anything made in the last 10 to 15 years. More technology and more greed equals less TLC when the manufacturing and engineering process is happening.
Old Jan 24, 2019 | 02:46 PM
REBEL59's Avatar
Sorry...Not sure of what way you are going with your response, are you agreeing about heater core or saying a blend door?
As long as position outlets are working and you get proper heat out the left(drivers side) then it can only be the core, and that is due to the way it is mounted inside the HVAC box inside the dash. Heck of a big job to do, I did a core on our 04 Neon and that was bad enough! I found a way to cut the HVAC box open to remove it's core(and seal it back up) without having to have the A/C system evacuated and then recharged after. But still had to take the whole dash and steering column out to get to the HVAC box! I would DRED doing one on a 200/Avenger!
Alice Goetschius
Dec 11, 2019 02:22 PM
JoeWavelength
Oct 15, 2017 07:33 PM
Triplecrown
Jan 5, 2016 02:00 PM
pacifica07
Jun 8, 2011 04:57 PM
simonda
Jan 3, 2010 02:44 PM
