2013 chrysler 200 brake issue
Old Dec 2, 2018 | 10:21 AM
ktsmith1993's Avatar
Default 2013 chrysler 200 brake issue
So, the other day the brakes went out in my chrysler 200. I figured out it waa the driver side rear caliper, so I replaced it and for some reason when I press on the brake pedal, the caliper does nothing. I opened up the bleeder valve and it seems that the fluid is not going coming out as fast as it should without forcing it, its barely a drip. In asking here first before I go into buying more parts, I was thinking it needed a new brake hose, but I just want some opinions on it first. This is the first time ive ever had this issue. Also I did fill up the MC with brake fluid before trying to pump the brakes.
Old Dec 3, 2018 | 10:42 AM
Try disconnecting the hose at the car end and pumping the pedal. If you have flow, then re-connect and disconnect at the caliper end and try pumping again. If no flow at that time, the problem is the hose. If no flow the first time, may be a plugged, kinked brake line. I had a similar problem a number of years ago on a front caliper on a minivan. The hose was plugged and would let a little fluid flow to the caliper but not return. Not sure how that comes to be but replacing the hose cured the problem.
Mike Tucker
Aug 5, 2019 01:42 PM
squills
May 5, 2018 04:59 PM
MoparTOCBTM
May 7, 2015 09:14 PM
Jberger
Feb 23, 2013 09:47 PM
donnyohs
Feb 19, 2009 08:14 AM
