2014 - 200S - Drvr Side Eng Oil Leak
Old Jan 16, 2018 | 02:26 PM
Cap's Avatar
Cap
Exclamation 2014 - 200S - Drvr Side Eng Oil Leak
Good Afternoon All,
I have a 2014, 200S w/55K miles on it. I discovered a pretty active leak yesterday. It seems to be on the drivers side of the engine block (perhaps the front main seal?). Has anyone experienced this premature failure? Any assistance with what it may be, or if it is covered under the drive train warrantee, would be helpful.
Thank You in Advance, Cap
Old Jan 16, 2018 | 03:50 PM
REBEL59's Avatar
Is the motor the pentastar 3.6 v6? if so the oil filter/ cooler assy is prone to leak..REPLACEMENT is the recommended fix. I t is located on top of the motor , under the dress up cover.
Old Jan 16, 2018 | 06:24 PM
Front main seal would be on the passenger side, down low. Read through your warranty documents and if you think it should be covered, take it to the dealer and state your case.
andreawright
Jan 9, 2016 02:33 PM
metalman3
Mar 10, 2015 08:47 PM
reevesjo
Feb 19, 2012 04:25 PM
ladyas
Dec 13, 2009 06:09 PM
mysbring01
Dec 8, 2006 02:07 AM
