96 JXI hiccups
Old Dec 21, 2013 | 05:45 PM
noasinc's Avatar
Default 96 JXI hiccups
As I am driving the engine would hiccup random meaning it would stall for a split of a second. I get that forward jolt of inertia. One time it even stalled but I could restart after turning it off. Just wonderring what would be causing this. The 96 is has only 135K miles and runs great with plenty pep and power. I have replaced timing belet and done heads rebuilt, new TBP sensor, IAC motor, valve cover gaskets, spark plugs and wires, EGR valve and hoses. I also had replaced a distributor but I have suspicion that the rotor was changed only and the charge was for the whole thing. That is when I started to work on it myself and done all the above work. I would entertain any ideas where should I look for the fix.
Old Dec 22, 2013 | 09:25 AM
If you spend some time reading the forum here you will probably come to the conclusion that a good many problems associated with V-6 engines from the '90's Sebrings are traceable to the distributor. Your post also suspects the distributor.
A heavy miss as you describe it should generate an error code. Check for codes first.
jonathan080908
Apr 19, 2012 05:20 PM
sonyatracie
Mar 10, 2011 02:12 PM
srt4_night_rider
Feb 15, 2006 01:49 PM
carman4433
Aug 8, 2005 08:00 PM
JXI101
Jun 25, 2005 12:19 AM
