96 Sebring won't start
Old Oct 1, 2008 | 01:25 PM
confused's Avatar
Default 96 Sebring won't start
Parked 96 Sebring one night, car was running fine with no problems. Will not start again. ASD relay not energizing. Replaced relay in case of bad contacts. No help. PCM does not list any faults. Can anyone help?
Old Oct 1, 2008 | 02:41 PM
Default RE: 96 Sebring won't start
Could be lots of things. I assume you have a good battery and it cranks but won't fire. Check for fuel pressure/flow. Check coil and wiring. Possible timing belt/chain problem.
Old Nov 23, 2008 | 07:05 AM
maddmudder77's Avatar
just had the same problem this week, replaced the distributer (could just replace the coil) and she started right up. could also be fuel pump, pcm, timing belt.
Old Nov 25, 2008 | 01:39 AM
irdaneel's Avatar
Curious, why do you say the ASD is not energizing? Did it give you a code?
Crankshaft position sensors can also do this. (With or without codes)
Usually the distributor will throw a code, but not always, especially if it has the camshaft position sensor built in.
2005Cruiser
Aug 20, 2018 08:46 PM
jbda
Cirrus & Breeze
Apr 1, 2013 11:09 AM
davec00
Feb 4, 2012 12:28 AM
laura
Apr 11, 2010 08:48 PM
tireburner454
Jul 10, 2007 07:17 PM
