97 sebring 2.5 that run some times only in idle
Old Sep 8, 2008 | 10:11 AM
jaydub54's Avatar
Default 97 sebring 2.5 that run some times only in idle
first ive check almost every thing yet u say check the circuit. i have three wire on tps and volts were 5.60 on ohm meter what should it read? one more thing after i erase all codes how is it that one or two codes stay before i crank po122 or p0123
Old Sep 11, 2008 | 06:32 PM
Default RE: 97 sebring 2.5 that run some times only in idle
The voltagefrom the TPS should be between 0.16 and 4.5 volts. You may need to both replace the sensor AND check for the source of high voltage.
It's best to just "reply" rather than starting a new thread for an old problem.
NoFurula
Mar 31, 2015 07:01 AM
Alex255
Feb 26, 2015 06:53 PM
Alex255
Feb 23, 2015 11:42 PM
XtremeCuztoms
Dec 19, 2006 02:22 PM
Mar 23, 2006 05:00 AM
