97' Sebring Convertible - No Start/No Spark
Old Nov 3, 2010 | 05:33 PM
sramelyk's Avatar
Well. To no freaking surprise the replacement of the sensor did nothing! Still no spark.. I want to dump this car in the river! I don't even know what to do next. Anyone know where the ASD relay is? Could this be the problem? How can I be sure votage is going to the distributor? How can I be sure the fuel pump is coming on? I don't hear anything but not sure what I'm listening for. I am so frustrated with this car.
Old Nov 3, 2010 | 06:12 PM
sramelyk's Avatar
I feel like I'm talking to myself.. But thats ok, hoping someone stumbles across this and tells me the one thing I am missing.
Anyways.. Found the ASD relay in a cluster of 4 behind the PCM. They all looked the same including the starter relay. So, I switched the ASD relay with the starter relay and still no spark, but the starter worked so I know the relay is good.
I need help.. How do I know if the fuel pump is coming on?
Old Nov 3, 2010 | 10:05 PM
You could run a fuel pressure test using a pressure gauge and the necessary fittings. You could get a rough idea if the fuel pump is working by relieving all the fuel line pressure and then re-connecting the system, turning on the key and listening for the pump to come on for a couple of seconds to build pressure back up. It won't tell you if the pressure is high enough to work properly though. I don't think there is any code for low fuel pressure, so if that's the problem, it won't show up as an OBD reading.
Old Nov 5, 2010 | 03:41 PM
sramelyk's Avatar
This wouldn't keep the car from sparking though would it? I mean if something is wrong with the fuel pump?
Old Nov 5, 2010 | 09:06 PM
  #15
TNtech's Avatar
If your cam/crank sensors are not in sync you will get no fire. Check your timing belt. Does it sound funny when you crank it over?
Old Nov 6, 2010 | 12:11 AM
  #16
sramelyk's Avatar
Describe funny.. I don't think so.. Just cranks and no fire.. But, that being said, I really don't know.
When you say cam/crank sensors in sync how do I know if they are or aren't and how would I fix that? I honestly didn't think about the timing belt at all.. I'll check that for sure.
Old Nov 6, 2010 | 12:36 PM
  #17
TNtech's Avatar
You have to read the cam/crank signals sync on a scan tool. Funny as in sounds more like an air compressor than an engine turning over.
WillQRose
Oct 18, 2018 07:18 PM
TheFox302
Mar 1, 2017 10:48 AM
austin
Cirrus & Breeze
Sep 16, 2012 09:09 PM
jayboy
Feb 21, 2012 10:48 PM
subscript
May 8, 2010 06:58 AM
