98 sebring "evap large leak" help
Old Nov 26, 2017 | 11:16 AM
Dsw422's Avatar
Default 98 sebring "evap large leak" help
Hey guys.. new to the forum. I have a 98 sebring LXI v6.. I have a engine code saying I have a evap emission large leak.. I can hear whistling coming from the front of the engine near the a.c. compressor area.. I checked all hoses and seem to be fine. The sound sounds like it's coming from behind the plastic front cover.. could that be where the leak is before I go tearing the car apart?
thanks for any help.
Old Nov 26, 2017 | 06:02 PM
flaokie's Avatar
I'm new here too - I've had my '99 for 6 years, but have not yet had to fool with the EVAP system.
The EVAP purge solenoid is located down in that area.
It is used to control/regulate both pressure and vacuum in the EVAP system.
If it is not operating correctly, or the hoses and/or connections are leaking, it can cause EVAP errors.
Last I looked a replacement solenoid was around $30.
It looks like this when you look down at the top of it.
Old Nov 26, 2017 | 06:45 PM
Dsw422's Avatar
Attachment 2136
thanks man.. unfortunately can't load or see the pic u sent.. I'll Google the solenoid and see if I can find it to see if it is bad. Thanks for ur help
Old Nov 27, 2017 | 09:16 AM
You can pinpoint the location of a vacuum leak using a length of tubing or hose by holding one end near your ear and putting the other end where you think the leak is located. It'll get louder when you are right at the leak.
a_kraker99
May 8, 2021 09:48 AM
Chrysler Forum Editor
Nov 7, 2016 03:08 PM
HowieF16
Oct 13, 2014 03:49 PM
rocksockdoc
Oct 17, 2013 11:12 AM
vtraudt
Oct 11, 2008 09:24 AM
