99 LXi Door speaker removal.
Old Sep 6, 2005 | 02:27 PM
Dusto's Avatar
Default 99 LXi Door speaker removal.
I finally blew the passenger door speaker from the infinity system last week. Problem is I can't tell if I need to pull the entire door apart to unhook the speaker until I can replace it, or if there is a much simplier way. If anyone has delt with this, I would greatly appreciate any and all help.
Thanks in Advance!
Dustin
Old Sep 6, 2005 | 04:33 PM
BadStratRT's Avatar
Administrator
Default RE: 99 LXi Door speaker removal.
hmmm..i have not removed mine, so im not sure...however, i used to work at a dodge dealership, and if you call a parts department, and tell them you work at a shop, and youre doing a window motor regulator, and you need to know how everything comes apart. OR go to a dealership and they will show you a schematic of the door assembly.
Old Oct 3, 2005 | 06:17 PM
Dusto's Avatar
Well, finally figured it out. You have to take the entire door panel off to disconnect the speaker, ugh!
tbird2340
Aug 9, 2011 09:57 PM
main273
Apr 30, 2011 03:34 PM
bramfrank
Dec 27, 2008 03:16 PM
Newtoo300s
Jun 2, 2008 01:56 PM
pimpinc333
Mar 28, 2007 10:17 PM
