ABS light on
Old Oct 29, 2013 | 10:03 AM
alwal0307's Avatar
Default ABS light on
I've had a new NSF wheel bearing fitted and now the ABS orange warning light is on Does this need resetting to clear? or is there a problem. I would of thought it would clear itself but hasn't.
Old Oct 29, 2013 | 03:05 PM
The light is on for a reason. A fault code is stored in the computer. Get it read and find out why it's on. Nobody here can tell you why the light is on without just guessing.
Old Oct 29, 2013 | 07:30 PM
alwal0307's Avatar
The question i was asking if there was no fault now would the warning light go out or do you need to reset.the light came on after fitting a new Wheel bearing.
Old Oct 29, 2013 | 09:35 PM
u broke the sensor u go the wrong tone wheel on the bearing any number of items.
Old Nov 7, 2013 | 02:07 PM
alwal0307's Avatar
I'm Having to buy a genuine Chrysler Wheel bearing/wheel hub there seem to be no one other that the main dealer in the UK can get this part or equivelant part. Problem is Chryslers price is £230. IMO that is disgusting.
Old Nov 7, 2013 | 09:36 PM
Try rockauto.com. They sell over there.
But be sure you're not throwing expensive parts at a problem before you know what the problem is. Get those codes read first. That's the whole purpose of having error codes.
Old Nov 8, 2013 | 03:48 PM
alwal0307's Avatar
Hi Dcotter
I've already received the parts from Chrysler, (being fitted Tuesday),the NSF one i had fitted must be wrong hence the ABS problem.tried entering the genuine part number into Rockauto.com came up with nothing. Part no is K05154211AA.(the error code said NSF sensor)this only came on after renewing Wheel Bearing/Hub.
Old Nov 13, 2013 | 08:26 AM
alwal0307's Avatar
Had new Wheel bearing/hubs fitted ABS now OK. In UK can only get these bearing from main dealer.
jimmy154
Dec 14, 2019 09:45 PM
mario65
Jun 3, 2008 08:27 PM
milciste
Dec 15, 2007 08:42 PM
notVERYpleased
Jul 24, 2007 10:19 AM
chrysler34
Mar 18, 2007 03:33 PM
