blower fan
Old Nov 23, 2008 | 07:14 PM
willys1941's Avatar
Default blower fan
2003 chrysler seibring. Blower fan motor runs only on high. Checked 30 amp blower motor fuse and it was ok. Changed control panel and still fan only runs on high.
Old Nov 23, 2008 | 07:26 PM
xfire04's Avatar
Default RE: blower fan
sounds like your blower resistor is bad not sure of the location on your car a sebring owner might chime in an tell you the
location
Old Nov 23, 2008 | 10:18 PM
Yeah, it's the resistor. There are severalthreads about this problem on this board, but here goes.
The resistor is accessible from inside the car on the passenger side, below the glove box area. Pull off the silencer panel down there, and look for a connector with a bunch of wires coming out of the heater-A/C housing. Disconnect the plug, and there are two screws holding the resistor in place. Remove the screws and pull the resistor.
You can but a replacement at your Chrysler or Dodge dealer. The new one will be fatter than what came out. You will need to open up the hole with a rat-tail file. DON'T try to cut down the new one to fit the old hole, and don't jam it in.
Put it back together and you'll have all your blower speeds back.
This is not a difficult job,but harder depending on how big a person you are due to the fact that you are working in a tight place.
Old Nov 24, 2008 | 08:42 PM
xfire04's Avatar
hey dcotter0579 you no the sebring do you work in the car repair your step by step is very good
Old Nov 24, 2008 | 08:51 PM
xfire04's Avatar
looks we have the the same first names mine is Dennis also
Old Nov 25, 2008 | 12:28 PM
I replaced my own resistor. It's the voice of experience.
I also own a set of shop manuals.
JamesEiland
Mar 11, 2012 08:31 PM
colbertgang
Apr 26, 2009 09:30 PM
rkluck
Mar 29, 2008 03:14 PM
United1
Jan 2, 2008 10:45 AM
greenman
Mar 2, 2006 05:19 PM
