Brake fluid leak, Rear Passenger drum
Old Dec 10, 2018 | 07:27 PM
2004SebringSedan2.4L's Avatar
Default Brake fluid leak, Rear Passenger drum
The wheel bearing hasn't gone out yet, uses about 1 ounce of brake fluid per 100 miles city driving. I left the e-brake on slightly by accident, I guess I nudged it while I was driving. My friend said its a $15 part and that the leak must be from the brake cylinder. Does this sound about right, can I do it myself or is it a must-do in a shop?
Old Dec 11, 2018 | 05:02 AM
REBEL59's Avatar
Yes if you can see wetness on the backing plate and drum, a leaking wheel cylinder, and DIY depends on your repair skill level and tools available that you have.
Just a STRONG suggestion being an 04 model..do BOTH sides for cylinders and new shoes(fluid soaked..not good), and don't forget to measure for brake drum inner diameter wear(you may need to get new brake drums. All in all this is not that complicated a job to do, just take apart ONE side so you have the other for reference.
Old Dec 11, 2018 | 01:06 PM
BiliTheAxe's Avatar
It can help a lot if you take pictures with your phone or a tablet as you take apart the brakes, so that you have a good reference for reassembly.
Old May 10, 2019 | 09:55 PM
I took to brake place, was raining and didn't want to do it myself :' ) They said the brake line had collapsed (probably due to the heat.) Was user error.
MiniVanMike
Jul 31, 2018 09:28 AM
goggs
May 18, 2013 04:28 PM
arveetek
Jan 31, 2011 10:15 AM
yaxo11
Cirrus & Breeze
May 5, 2010 10:23 PM
jquinones
May 24, 2008 04:12 AM
