A/C compressor
Old Feb 20, 2009 | 12:58 PM
Naison's Avatar
Default A/C compressor
Is there any way you can take the bearings off the compressor on Sebring '02 2.7 without taking the lines off. I took the belt off and when you move the A/C compressor pulley by hand it makes noise.Also about the idler pulley. When are you suppose to replace it? The belt looks kind of cracked So I'll probably replace it. I guess the main thing is the A/C compressor. Car has about 98000 miles.
Аny suggestions?
Old Feb 20, 2009 | 08:05 PM
moe's Avatar
moe
going to be tight in the car ,but i beleive you can remove the clutch housing.might need snap ring plyers
Old Feb 21, 2009 | 07:50 PM
Rick99's Avatar
I just changed out the compressor in mine last summer and I would not want to try to work a clutch puller in there, but perhaps it can be done. The more relevant thing though is that a clutch pulley will cost close to $200-- that might be better spent toward a complete compressor since yours is probably old.
paul.siwek
19
May 23, 2011 12:10 AM
speretz
Sep 14, 2008 08:26 PM
Attitude0917
Mar 22, 2008 08:04 PM
linda bell
Dec 8, 2006 07:28 PM
rhockley
Jan 17, 2006 08:42 PM
