Caliper bracket bolt torque specs - 2012 Chrysler 200
Old May 16, 2019 | 12:47 PM
stopchrying's Avatar
Default Caliper bracket bolt torque specs - 2012 Chrysler 200
Can someone here please let me know what the torque specs are for the caliper bracket bolts (the ones you unscrew so that you can remove the rotors). I can't find anything online.
Old May 19, 2019 | 04:13 PM
Bolt torque specs are a function of the size of the bolt. There are charts on line you can find easily. Those bolts holding the caliper are pretty good sized. They will take a pretty good torque. For most purposes, the torque for a big bolt like that is "all you can put on it with a normal ½ inch ratchet." (Unless you're an Olympic weightlifter. Then put on a little less force than that.) The point is, that an exact torque is not critical. You want it good and tight.
dontippet
Oct 3, 2018 11:40 PM
skid2964
Apr 24, 2016 05:50 PM
gevans@hcc.net
Nov 12, 2011 05:56 PM
StratLou
May 15, 2011 12:11 AM
mcneesejd
Jul 29, 2009 01:17 PM
