Chrysler 200 -Warning lights flashing speedometer needle dropping
Old Jun 12, 2019 | 09:42 PM
Neil Radley's Avatar
Default Chrysler 200 -Warning lights flashing speedometer needle dropping
Driving home tonight and the speedometer needle randomly started dropping and warning lights would come on.
Noticed when I stopped the car that the lights on the dash were going dimmer and then lighter, which when I checked matched the exterior lights too.
Any ideas?
Old Jun 12, 2019 | 10:16 PM
REBEL59's Avatar
Alternator trouble? What warning lights and what year and engine
Old Jun 12, 2019 | 10:29 PM
2011 Chrysler 200 3.6
I took a video -
Old Jun 13, 2019 | 05:26 AM
REBEL59's Avatar
Thanks, the info. helps out greatly. Now FIRST and most basic step is to check the battery cables and battery for good clean connections(they love to corrode), and also have the battery load tested by someplace like Auto Zone(they perform this test for free) If the battery is more than 4 years old I would almost bet on a dying battery!
Old Aug 5, 2019 | 12:56 PM
boatmoter's Avatar
looks like the lights are flickering. so I would do a voltage test on the charging system, if it test out ok,then you may have a defective instrument cluster
Old Aug 10, 2021 | 05:55 PM
Mortisha's Avatar
Default Chrysler 200 warning lights flashing speedometer needle dropping
I took a video - https://youtu.be/3_wvi_n3teo
Did you ever find out what was wrong with your car. I have a Chrysler 200 2013 and it is doing the exact same thing.
Old Aug 10, 2021 | 07:47 PM
Get a code reader hooked up to it and gather the error code(s) that almost certainly exist in the computer. Those codes will guide you toward a proper repair. Depending on where you live, many auto pats stores will read the codes for you for free.
Old Aug 12, 2021 | 01:36 PM
Mortisha's Avatar
Thank you for your help. I'm glad I didn't pay for repairs. The black wire that's connected to the jump post was loose. I tightened it up, problems solved in less than a min. Thank you again.
Sarah Turner
Dec 19, 2017 09:27 AM
Je27ff
Nov 22, 2017 05:21 PM
Darrenmbrown
Oct 9, 2013 02:23 PM
jvh24521
Sep 10, 2012 08:39 PM
littleman
Feb 21, 2011 03:23 PM
