downstream o2 sensor
Old Oct 14, 2010 | 05:21 PM
artie's Avatar
Default downstream o2 sensor
I have a 2002 chrysler sebring with the 2.7 engine in it. I keep getting the code downstream o2 sensor is neither positive or negative. I changed both oxygen sensors ( the upstream and downstream) and did a vacuum test on the cat which was o.k. Should I still go ahead and change the cat or try something else?
Old Oct 14, 2010 | 06:14 PM
TNtech's Avatar
List the codes please.
Old Oct 14, 2010 | 06:56 PM
artie's Avatar
The code I get is 0140
Old Oct 14, 2010 | 07:54 PM
You say you changed "both" oxygen sensors. There are 4 oxygen sensors on the 2.7L engine. The code refers to bank 1 (rear bank) downstream sensor. Is that the one you changed?
Old Oct 14, 2010 | 08:32 PM
artie's Avatar
Thank you I changed the front downstream sensor. I will change the rear bank sensor and let you know.
billnye50
Mar 10, 2011 01:47 PM
