Drum in disc parking brake(e-brake)
Old Jun 1, 2009 | 09:02 AM
andrew143's Avatar
Default Drum in disc parking brake(e-brake)
I just replaced the rear pads and rotors in my '02 Sebring with 2nd line AC Delco rotors and Raybestos pads. I had quite a bit of difficulty getting the rotors off in the first place due to the parking brake shoes. When I put the replacement rotors on they seemed to just slip on ok. I installed the pads and replaced the calipers. Put everything back together and after taking a test drive I noticed hesitation and a squeeking noise in the passenger side rear. Upon removing the rotor I could see some brake dust from the drum area and noticed that the parking brake shoes were hot. I tried to adjust the star nut on the parking brake assembly to where I could not feel any kind of resistance on the rotor from the parking brake but the disc is just not turning smoothly and I the star nut is at it's lowest setting. I can think of a few things to try:
1. Remove the rotor and swap it with the drivers side rotor
2. Check the 'roundness' of the drum surface with a caliper as it's possible i've received a rotor thats not truely round.
Any other suggestions? Or should I just exchange the rotor for a new one??
Old Jun 1, 2009 | 04:11 PM
Double check the position of the shoes in the problem side. I think it's much more likely that the shoes got jostled during disassembly and may be a little out of position. A non-conforming rotor is pretty unlikely. The outside diameter of the shoes in place should be 6.75 inches. Check for a pin mis-located or a clip not properly on the pin.
Old Jun 2, 2009 | 06:44 AM
marktoyota's Avatar
please visit this web site, may be you will find all your need. theautopartsshop.com, you will find all about auto parts. Chrysler Cirrus Timing Belt
andyb2000
Jul 15, 2015 11:53 AM
Tetleysmooth
Jan 10, 2013 12:13 AM
dcm1971
Oct 26, 2009 06:45 PM
elboroom
Mar 20, 2009 06:52 AM
posjr
Cirrus & Breeze
Jan 17, 2007 02:28 AM
