engine swap from conv. to coupe
Old 12-01-2011, 09:58 AM
heminow's Avatar
Default engine swap from conv. to coupe
will the 2.5 from a '99 sebring conv. fit a 97 coupe
Old 12-01-2011, 09:45 PM
Might, with some work. The coupe was built by Mitsubishi, and it's a completely different vehicle. Exhaust, plumbing, wiring are going to be different.
Old 12-02-2011, 03:40 PM
heminow's Avatar
thanks dcotter, is the engine block the same, if yes will all the parts from the 97 fit on the '99 like water pump, mounts, brackets and etc??
thanks again
Old 12-03-2011, 09:26 AM
Sorry, don't know, never tried it. You might search chryslerparts.net to see if the part numbers are the same. I suspect the block might be the same, but the farther out you get, the more chance of differences.
wink1969
01-21-2011 04:20 PM
iNightmar3 XD
11-22-2010 11:00 AM
sebringit88
06-23-2010 06:39 PM
sebringphanatic
07-25-2009 12:03 AM
andbudzi
02-20-2008 04:07 PM
Quick Reply: engine swap from conv. to coupe
