Help Me Please
Old Jul 16, 2013 | 11:42 AM
chryslersmom05's Avatar
Default Help Me Please
I have a 2005 Chrysler Sebring. Lately my engine light has bee turning on and when its on and i stop and take ove again it chugs for a bit then is fine until i stop again. If i turn off the car amd sit for a minute when i start it again the light stays on but the car runs fine. After a couple trips like this the light will turn off when i start it again. Any help would be greatly appreciated. I was told it could be a cam shaft sensor but wondering if it could be something else.
Old Jul 16, 2013 | 02:46 PM
Whenever the "check engine light" comes on, there is an error code stored in the computer. You might be able to get it out by turning the key from off to on, then off and on again, and off and on one more time, leaving it in the "on" position. The error codes will be displayed where the odometer normally is.
Write down any numbers that come up there. If that doesn't work on your model, then take it to an AutoZone store (unless you are in California) where they will usually hook up a code reader for free and give you the error codes.
Those codes are called OBDII codes (for second generation on-board diagnostics) and if you look them up on the internet you can find out what is wrong with your car.
Without the codes, there's no point in guessing, which is all anybody here could do.
As you have asked, it could be the camshaft sensor, or it could be something else. It could be a hundred other things. Let's not guess.
Old Jul 16, 2013 | 10:19 PM
We did have it hooked up and it said it was the cam shaft sensor but the guy working was like well they may not be what it is. That the code was probably wrong. So if the code came up for the sensor i should just have it changed and see if its the problem I'm guessing.
Old Jul 17, 2013 | 09:01 AM
First thing I'd change was the mechanic. If the guy's working assumption is that the "code is probably wrong", then it's time to walk out the door and find a competent technician.
s.wilson1978@yahoo.com
Jul 12, 2011 02:19 PM
musicfreak2195
Jun 3, 2009 08:43 PM
cnixon
Jun 11, 2008 10:41 AM
stiffler30174
Nov 6, 2005 08:02 PM
fred
Jul 27, 2005 11:26 AM
