If I buy car with dead 2.7 what should I expect?
Old May 12, 2007 | 11:28 PM
car5car's Avatar
Default If I buy car with dead 2.7 what should I expect?
Should I get ready to install new crank? Or just rebuild heads? Is there chance just to replace bearings? Do they knock or seize? Coolant in oil will destroy crank bearings? Thanks.
Old May 18, 2007 | 09:16 PM
Blue07's Avatar
Default RE: If I buy car with dead 2.7 what should I expect?
Don't, unless it's REALLY cheap. Used motors are very expensive and rebuilts are VERY expensive.
Usually not worth the money to rebuild yourself.
Old May 19, 2007 | 02:16 AM
car5car's Avatar
Thanks for your responce. Did you ever fix 2.7? As far as I know dealerships don't fix engines. They can replace chain or head gasket but never mess with pistons and cranks. My question is which parts of engine go bad?
Old May 19, 2007 | 10:26 AM
Blue07's Avatar
Don't bother asking the dealerships. Find a local engine rebuilding shop andask them what damage they see and what can or can't be fixed. Probably going to get your the best answer that way.
The ones that come through my relatives salvage yard are always knocking severely or already locked up - ie bottom end failures.
They do NOT sell used 2.7 engines at any cost, regardless if they don't make noise, they all get dumped in a container. They don't want the hassle.
Old May 20, 2007 | 12:02 AM
car5car's Avatar
Thanks Blue. Locked up engines are usually need 1 new piston and set of rings but I hate to replace crank.
Old May 21, 2007 | 08:18 PM
jamie1's Avatar
ORIGINAL: car5car
We do engine work at my dealership all the time. Valve jobs,crank and piston replacement,you name it. It many cases though,it is CHEAPER to install a reman engine,then to try and rebuild the customers engine. As it has been said before,unless you are getting the car for free,I would not waste my time with a sebring with a seized 2.7L. Very expensive to replace.
Chrysler Forum Editor
Feb 9, 2015 01:08 PM
Daniel Kvasnicka
Sep 18, 2013 12:53 AM
cook2005
Jan 3, 2010 08:57 PM
Al B
Jun 23, 2008 11:34 AM
danielchi
May 20, 2007 08:42 PM
