Needing helps
Old Jul 3, 2023 | 01:46 AM
Normanchrsyler200cAWD2015's Avatar
Default Needing helps
Anyone have any idea what might be wrong with my Chrysler 200c AWD 3.6 Liter V 6
so here it goes i bought new park plugs-new coil pack- new ground wire- new battery- new alternator. The car was already PCM flash before in 2022 right before I bought
but the car will not hold a charge for more than 5 minutes. I need help finding a direct answer for this problem
Old Jul 4, 2023 | 09:47 PM
If your battery is running down in 5 minutes, you have a MAJOR short circuit. The kind of short that will cause large wires to smoke and small wires to catch fire. Somehow, I think if you had that kind of short you would have had need of the fire department long before now. How do you know your battery is run down. What symptoms does the car exhibit? Are there any fault codes?
gsnafu
May 23, 2020 04:26 PM
Joey Mitchell
Mar 12, 2020 06:57 PM
Zoomer55
Sep 23, 2019 04:27 PM
moparjj
Nov 6, 2017 10:12 AM
thissideup
Dec 7, 2015 10:40 PM
