No charging new alternator
Old Apr 5, 2022 | 08:51 PM
purplepuller's Avatar
Default No charging new alternator
2004 Sebring 2.4. Installed new alt. had negative cable unhooked up on inner fender well. Putting red wire back on alt.it sparked. finished putting back together and no charge.do not have power at 20 amp fuse under hood Fuse box labeled Alt. with key on. did I burn something up when it sparked?
Old Apr 5, 2022 | 10:50 PM
fuse 25 20 amp will only have power when the asd relay is on which is only when running check you main power wire at the alternator does it have 12v?
Old Apr 6, 2022 | 06:58 PM
Started car checked voltage. have 12 volts on big red wire and checked with test light on Green wire going to alt. Have power there. While car is running belt started slipping and battery light was on.. I also had installed new tensioner Well that was problem. Cheap China junk! put on old tensioner and plus battery crapped out on me (8 years old). New battery and everything is fine.
tcwaltz
May 18, 2021 12:53 PM
moparjj
Nov 6, 2017 10:12 AM
mechaniker1986
Dec 1, 2016 01:47 PM
jquinones
Nov 30, 2007 07:30 PM
jeffmac2112
Jun 21, 2007 11:15 AM
