No power windows, no blower motor, airbag light is on
Old Jul 11, 2024 | 08:44 PM
Aussysledge's Avatar
Default No power windows, no blower motor, airbag light is on
https://www.chryslerforum.com/forum/chrysler-200-sebring-14/2001-sebring-no-blower-windows-airbaglighton-fuse-10578/ having this same issue but I can't figure out what things that are causing it, I swapped out the 40 amp ignition jcase and checked my two 30 am breakers for continuity on my multimeter along with all other fuses I could check with my meter and I don't see anything bad. My fuse does not blow like it does in that post. I swapped the ignition fuse for a different one already. Maybe it's what that fuse connects to, which I believe is my ignition switch.
Old Jul 12, 2024 | 08:15 AM
ggoose's Avatar
Please start with year, model and engine.
Does the engine turn-over and start? OP had issue with fuse popping when trying to start the car. This would be fuse #8, 20amp, under the hood. It is used for starting but provides power to a number of items when ignition in not in the start position (i.e. acc/run). Question - does the radio work? It gets power through the same fuse.
As a note, if fuse #8 is popping, it indicates the starter may be failing.
Old Jul 12, 2024 | 01:42 PM
Hey sorry for not providing the extra info, it's a 2005 Chrysler Sebring convertible 2.7. radio still works but windows and blower motor just stopped working. No intermittent failure either. Just a airbag light that comes on as well now. Ya I can't drive the car in Florida heat now
Old Jul 13, 2024 | 02:35 PM
Also yes car starts and runs normal too
Old Jul 14, 2024 | 08:19 PM
check for fuses to thoes electrical items is there power on both sides?
Killavolt
Oct 1, 2018 02:51 PM
ebby69k
Jul 9, 2013 08:31 AM
tyeaway
Sep 19, 2012 04:34 PM
Pac08
Sep 13, 2011 02:09 PM
UncleAndy
Jan 14, 2010 01:17 PM
