Noise in the front
Old Jun 4, 2009 | 07:00 AM
blindmutt's Avatar
Default Noise in the front
There is a rubbing/vibration coming from the driver side front, i's there when you go straight and when you turn left, when you turn the wheel to the right (even slightly) the noise goes away. Any suggestions??
2004 Sebring sedan 82xxx miles
Old Jun 5, 2009 | 08:50 AM
irdaneel's Avatar
Look for loose body parts first. Then inspect your tires very closely to see if you can spot where something is rubbing against them. Pay particular attention to where your brake lines are routed, as you don't want to rub a hole in them.
Old Jun 12, 2009 | 11:04 PM
monique111's Avatar
Well if its a vibration, first I would check to make sure you have the right torque specs on your lug nuts. I know it sounds trivial but you would be surprised as to how many people over look that small detail. If its a rubbing, I agree to check brake lines. but also check your mud shields, most of those clips are plastic and break easily. Let me know if that helps, if not I can give you a few more things to check.
rtp
May 25, 2024 07:40 PM
bgeise
Nov 5, 2014 03:38 PM
matune1
Jul 28, 2005 05:43 AM
MOHAMMEDHU2003
Jul 22, 2005 04:51 AM
Vandal_Mav
May 19, 2005 08:06 PM
