overheating chasedown
Old May 7, 2014 | 09:43 AM
Did you test the radiator cap? At what pressure does it begin relieving pressure? If the system has high pressure, it's the fault of the cap. The cap determines the system pressure. It should be between 14 and 18 psi.
Old May 7, 2014 | 10:32 AM
npereza5's Avatar
Also when the cap is off and i start the car. There are constant bubbles coming from the system. It almost looks like soda fiz.
Old May 7, 2014 | 10:33 AM
npereza5's Avatar
I have not pressure tested the cap. Its an 18lb cap and does relieve pressure because I hear it bubbling in the overflow tank but I do not know at what pressure it begins to relieve it at.
Old May 7, 2014 | 10:38 AM
npereza5's Avatar
I'll get a new cap and retest the system.
Old May 12, 2014 | 06:08 PM
  #15
npereza5's Avatar
Problem Found: it was the head gasket. There was no visable cracks but the fiberlock sealant I put into the car was gunked up on a section between the 3 cylinder and the water line. So my guess is going to be under torqued gasket or warped head. The head is at the machine shop now getting checked out and redone. Thanks for the responses.
Old Jul 4, 2021 | 05:37 AM
  #16
TRometti's Avatar
Originally Posted by npereza5
I was using water for test purposes. I purchased a new radiator and installed it. I ran the pressure test again and it lost pressure but this time at a very slow rate with no visible external leaks. Does this sound safe to say its a head gasket?
Also once the system gets warms its constantly boiling in to the reservoir.
2014 chrystler 200 over heating issue. Where your radiator cap goes on to. if you change that because they warp it fixed my over heating issue. I happen to push down on the radiator cap when it was over heating in my over flow and it stopped boiling so changed it and have had no issues since. I don't know much about cars so sry for the wording .first time putting anything on one of these sites .
Old Jul 6, 2021 | 01:06 PM
  #17
DavidBoren's Avatar
Thank you for posting. You deserve a firm handshake and commendation... your first post shows that you know how to use the search function. That's awesome.
Old Sep 7, 2021 | 03:28 PM
  #18
Peter GH's Avatar
Default 2014 Chrysler 200, overheating issues
Hey Guys, I just bought an 03 sebring with a 2.4L, its having overheating issues. Both radiator hoses become very hard as well. The fans are working and I tested the thermostat in a pit of boiling water and it opened up. I bled the system of air twice and no different results came up. I also block tested with the liquid and had no color change in the testing device. I did a compression test with the coil pack unplugged and had 105 110 105 100 on the cylinders and the spark plugs looked clean. I also ran the car with the radiator cap off to see the thermostat open and when it did water came splashing out.
I am not sure if its the water pump or the headgasket or both? I am going to rent a pressure tester today and will post results. Any insight at all would be great, I am not at all familiar with the 2.4L engine
Please i have same issues, i have bought a new thermostat and a radiator cap but still the car overheats. I have been advised by my mechanic to take out the thermostat and connect my fans directly to the battery. PLEASE I NEED HELP AS TO HOW TO STOP THIS OVERHEATING ISSUE.
Old Sep 7, 2021 | 08:58 PM
  #19
Possible causes of overheating in no particular order:
Bad thermostat.
Thermostat installed backwards.
Bad radiator cap.
Improper mixture of antifreeze.
Clogged radiator (internal).
Clogged radiator (external).
Low coolant. (Need to find cause)
Inoperative fan(s).
Radiator hose clogged.
Engine running too lean.
Air in system (need to find cause).
Head gasket leaking to coolant.
Dirty coolant passages.
Water pump not circulating coolant.
Start with the cheapest things and work through the list until you solve the problem.
Get a new mechanic. The advice he is giving you is not good.
furyfrank
Oct 8, 2018 11:53 AM
curiousv
Aug 8, 2017 06:16 PM
Lekim
11
Mar 12, 2015 04:24 AM
antoine88
Jul 23, 2012 08:20 PM
Too Distracted
Jun 8, 2009 10:45 PM
