Overheating/Water pump
Old Aug 4, 2011 | 10:02 PM
Greg's Avatar
Just finished taking the cams off..hope to get the heads tomorrow...Thanks CT for your help and advice! I'll get some pics tomorrow of what I find..
Old Aug 6, 2011 | 05:16 PM
Greg's Avatar
CT, Heads are off like you said, can't tell much... however when I pull the back head off #1 had a little puddle of anitfreeze in it...no other cylinder had any traces of antifreeze..? anyway took a pic so you could check it out...taking the heads to the machine shop monday...I have everything labeled like the book says so it will go back in the same place. Stopped at the parts house to get a price on a new timing kit and gasket set...475 for a new timing kit and 180 for a gasket set 65 for new hea bolts....Ouch!!!! I saw kits on ebay for a fraction of that cost...heck a master rebuild kit was like 700 bucks...from California...what your take on that?? the stuff from the parts house was car quest...anyway I'd be curious what everyone thinks! these days every dime counts!
Attached Thumbnails Overheating/Water pump-dscn0108a.jpg
Old Aug 6, 2011 | 09:12 PM
Are those coolant passages plugged up with rust? Might go a long way toward explaining the overheating problem.
Old Aug 6, 2011 | 10:03 PM
Greg's Avatar
DC, I'll take a closer look tomorrow..After I got the heads off I studies all my head bolts checking them to see if they were stretched, and I also bagged and labeled the lash adjuster too..and worked some on the exhaust manifolds getting them off the head. Standby
Old Aug 8, 2011 | 09:05 PM
  #15
Greg's Avatar
OK sorry for the delay..DC I looked over the block and heads, I know the pics show the rust but really it's not to bad...just looks bad in the pic..I took some more pics with and without the headgasket so you can get a better look. CT I made it to the machine shop this afternoon with the heads, told the guy what was going on and needed him to check the surfaces and pressure check both heads..he said they'd be ready tomorrow unless he found a problem...
Attached Thumbnails Overheating/Water pump-dscn0116a.jpg   Overheating/Water pump-dscn0117a.jpg
Old Aug 9, 2011 | 02:32 PM
  #16
Laimon's Avatar
I did have the very same problem.. heads were wrapped a bit that allowed pressure from combusion cylinder 1 & 5 to leak to coolant passages ..got false boiling antifreeze and overheat.
problem fixed by taking heads to machine shop, replaced water pump and thermostate ..
now like a new
Old Aug 10, 2011 | 12:06 PM
  #17
Greg's Avatar
OK...heard back from the machine shop! We were right! heads were warped! So they resurfaced them and pressure checked too..there ready for pick-up tonight! 120 bucks...heck that's a deal!
Old Aug 11, 2011 | 08:06 AM
  #18
Greg's Avatar
Hey everyone, just wanted to double check on the torque spec. haynes manual says
1-8 35
1-8 50
1-8 50
1-8 1/4 turn with a wrench
9-11 250 inch pounds..or 21 ft lbs
Old Aug 11, 2011 | 03:46 PM
  #19
Laimon's Avatar
i would refer to chyrsler service manual for torque sepcs...
and better to replace coolant canister pressure cap, since you've had several overheats ..
Old Aug 11, 2011 | 08:00 PM
  #20
Shop manual sez:
1-8 35
1-8 55
1-8 55
1-8 +90º Do not use a torque wrench for this step
9-11 250 in-lbs
Pretty close to what Haynes says.
