Persistent #2 misfire. 2.7
Old Jun 30, 2018 | 07:09 PM
Randy.olson's Avatar
Default Persistent #2 misfire. 2.7
hello I have a misfire and no signal to #2 injector. I have replaced the injector, the signal wire from the PCM and the PCM. Still no signal to injector. If I ground it out it will smooth out the run for a bit so I know it will put fuel in the cylinder when forced to. But I can’t get the signal from the PCM. Could I have two bad pcm drivers just for that cylinder? I did try the cam sensor unplug with no results. I have had the map sensor replaced also. I just tried to unplug the noise suppressor. No luck. What tells the computer to send the signal to the injector to open? Is it the crankshaft sensor?
I dont know where where else to fix this.
Also. I am guessing this is due to the no fuel and code throwing (engine light switches between on and flashing when driven) and putting the car in a limp mode but , it will also buck when taking it down the road if I get into the throttle too hard or if the motor is trying to downshift to get power... hoping that’s a symptom and not a cause of something even worse
thanks
Old Jun 30, 2018 | 07:12 PM
Default Btw. It’s a 2006 seabring convertible touring.
thanks
2006 seabring convertible 146000. Runs very well otherwise
chasy4
Jul 21, 2018 10:49 PM
Gutterbubba
Nov 2, 2015 12:38 PM
Tanveer Hoque
Nov 30, 2014 11:22 PM
MattStrike
Mar 22, 2013 04:52 PM
tc187211
Oct 25, 2011 09:45 PM
