Programming functions via AlfaOBD in Chrysler 200S
Old Nov 30, 2024 | 04:19 PM
marlus's Avatar
Default Programming functions via AlfaOBD in Chrysler 200S
Hi, I have a problem with programming functions via AlfaOBD in Chrysler 200S 2016 3.6 Pentastar.
Currently, the car has DRL lights off, and I would like them to be on. When I change the appropriate function in AlfaOBD and wait 5 minutes, this function does not work properly, and all possible errors are displayed on the dashboard (gearbox, power shifts, tire pressure and much more). The only thing I can do then is start the engine, but I cannot drive because the gearbox is blocked. When I set the DRL function back, there are no more errors and the car works normally.
At first I thought I did something wrong (I programmed it the same way as others show on YT), but I took the car to a car electrician and got exactly the same result. He does not know what is causing it.
Later I discovered that exactly the same thing happens when I want to change the value in any other function in the Body Computer. Is this some kind of watchdog? Does anyone know how to fix this?
JP89
Jul 18, 2024 05:42 AM
Chrysler borealis
May 10, 2023 11:17 PM
Mark Houghton
11
Mar 16, 2014 06:47 PM
cullymc
Sep 13, 2013 01:34 AM
