Rapid shake - Fault codes
Old Feb 26, 2012 | 01:33 PM
RCracer51's Avatar
Default Rapid shake - Fault codes
A few weeks ago I started getting a very rapid pulse/shake while braking. So, I changed out my front rotors and pads a few days ago to no avail. Wheel bearings are good.
2009 Sebring.. Following fault codes:
C102A–LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE.
C1014–LEFT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE.
C1035–RIGHT REAR WHEEL SPEED COMPARATIVE PERFORMANCE.
So what do these actually mean? Are my sensors going out and causing something to happen with my ABS?
Old Feb 26, 2012 | 01:40 PM
C102A-LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE
For a complete wiring diagram, refer to the Wiring Information.
When Monitored:
With the ignition on.
Set Condition:
When the Left Rear Wheel Speed Sensor (WSS) reading is different from the readings received from the other sensors at a vehicle speed above 40 km/h (25 mph). The Anti-Lock Brake Module compares WSS readings from side-to-side on an axle and front-to-rear.
Possible Causes
LEFT REAR WSS LOOSE - B3, B4 CIRCUITS/CONNECTOR/TERMINAL DAMAGE
IMPROPER LEFT REAR TIRE PRESSURE/MISMATCHED TIRES
LEFT REAR TONE WHEEL DAMAGE
AXLE SHAFT FASTENER HARDWARE
LEFT REAR WSS
ANTI-LOCK BRAKE MODULE
Jfizzle
Feb 22, 2020 04:37 PM
stewartsoftware
Apr 17, 2011 03:22 PM
bikerbeng
Oct 17, 2009 08:46 AM
New yorker 95
Jun 26, 2008 02:22 PM
97K15004WD
Aug 26, 2007 07:35 PM
