Rattling noise at idle
Old May 6, 2012 | 05:54 AM
Arthur Aghakhabian's Avatar
Default Rattling noise at idle
When the car is in park or any other gear (car is stationary, car is not moving) their is a rattling noise that comes from somewhere near the pedals, when I slightly depress the gas pedal the noise goes away, how can I stop the noise all together.
Old May 6, 2012 | 02:36 PM
Crawl under there and touch different things near where the rattle is coming from to see if you can find what it is that's rattling. Could be lots of things. If you can find it, figure out what needs to be done to stop it. There might be a screw loose or missing, or something is touching something that it shouldn't. Something as simple as tightening a screw or wrapping something with tape may be enough to cure the problem.
Old May 14, 2012 | 12:15 AM
it was actually something under the hood, the throttle cable wasn't clamped in properly, and it would vibrate against a plastic piece, causing the noise. It is all fixed now, thanks for the help.
Up4Si
11
Apr 25, 2011 07:47 AM
Wayne34UK
Mar 17, 2011 04:07 PM
craig
Apr 30, 2008 10:50 AM
Kevin
Apr 24, 2008 06:32 PM
tpacwa
Sep 29, 2007 12:06 AM
