Rear passenger window not working
Old Jan 6, 2016 | 11:34 AM
1.8TTony's Avatar
Default Rear passenger window not working
Ok, so I just got a 2002 Sebring limited. When I put the (convertible) top down, the passenger rear window doesn't go down. The other windows do go down partially. This is the first Chrysler convertible I've had. I am wondering how hard is it to replace the window motor.
Or, could the window not be operating due to a bad switch. Would it be a bad switch on the drivers door panel or the switch on the center console (convertible top switch).
Is there a way to test the power.....does each window have it's own power fuse and or circuit breaker.
Old Jan 6, 2016 | 02:58 PM
It could be the switch, the motor or the wiring in between, or it could be a mechanical problem with the regulator. There's also a module that runs all the windows down when you put the top down. And no, there is not a fuse/breaker for each window. Somebody's going to have to open things up and get in there with a tester to check for power and shorts and see what the problem is. If you're not comfortable doing it yourself, then your choice is to find a shop manual or hire somebody knowledgeable.
dedwardk
Jan 5, 2013 07:46 PM
motley1987
Jun 24, 2012 04:24 PM
dtoes91
Apr 29, 2009 04:34 PM
ctribou
Nov 1, 2008 07:13 PM
finlandmauri
Dec 26, 2007 09:39 PM
