Rear rubber brake hose 2006 Sebring Touring
Old Jun 7, 2021 | 10:02 AM
toyota's Avatar
Default Rear rubber brake hose 2006 Sebring Touring
I once replaced the Rear driver side rubber brake hose, because the rear wheel brakes were locked. It took me forever to figure that out as i bleed the brakes and rebuilt the caliper, but wheel still locked once i applied foot brake. Now two years later, i think i have same problem on rear right passenger side, the wheel locks up and gets very hot. I also did full brake job a while ago, so i think it must be same problem.
The rubber hoses look ok, but they appear not to allow brake ffluid to return back when i take my foot off the brakes under gravity when applying brakes because power brakes, it does stop the car and apply brakes, but when i take my foot off brake pedal, the fluid has to come back under gravity to brings the piston back in caliper.
So this week i will have to replace this brake hose as well.
Question:
Can one reuse the copper washer on the banjo bolt end of the brake hose?
i had a hard last time getting the replacement washer.
Thank you
Old Jun 7, 2021 | 03:41 PM
ggoose's Avatar
I would not reuse the washer.
I have always found the washer included with the brake hose. Check your package before you leave the store to be certain the washer is in the package.
Old Jun 7, 2021 | 03:56 PM
toyota's Avatar
Default Rubber brake hose copper washer. Radiator cap
Rubber brake hose and copper washer was in the packaging this time and it was a Rabestos brand for $22. Last time i brought one for the other side, it was $35 and no packaging or washers.That's Napa rip off for you in Canada, plus 13% sales tax on everything.
Also replaced Radiator Cap, so lets see if that stops the antifreeze gargling in the bottle.
Mike Tucker
Aug 5, 2019 01:42 PM
ktsmith1993
Dec 3, 2018 10:42 AM
MoparTOCBTM
May 7, 2015 09:14 PM
David Rovka
Sep 22, 2013 07:09 PM
jfmerk
May 29, 2011 01:44 PM
