Rear rubber brake hose 2006 Sebring Touring
I once replaced the Rear driver side rubber brake hose, because the rear wheel brakes were locked. It took me forever to figure that out as i bleed the brakes and rebuilt the caliper, but wheel still locked once i applied foot brake. Now two years later, i think i have same problem on rear right passenger side, the wheel locks up and gets very hot. I also did full brake job a while ago, so i think it must be same problem.
The rubber hoses look ok, but they appear not to allow brake ffluid to return back when i take my foot off the brakes under gravity when applying brakes because power brakes, it does stop the car and apply brakes, but when i take my foot off brake pedal, the fluid has to come back under gravity to brings the piston back in caliper.
So this week i will have to replace this brake hose as well.
Question:
Can one reuse the copper washer on the banjo bolt end of the brake hose?
i had a hard last time getting the replacement washer.
Thank you
Question:
Thank you
Rubber brake hose and copper washer was in the packaging this time and it was a Rabestos brand for $22. Last time i brought one for the other side, it was $35 and no packaging or washers.That's Napa rip off for you in Canada, plus 13% sales tax on everything.
Also replaced Radiator Cap, so lets see if that stops the antifreeze gargling in the bottle.
