Rear upper ball joints
Old May 20, 2010 | 11:35 AM
mwstant's Avatar
Default Rear upper ball joints
I am having trouble removing the old upper ball joint in my 02 sebring sedan. I have the bolt free but the ball joint wont come out. Any suggestions?
Old May 20, 2010 | 01:49 PM
You need a special tool, a ball joint puller of the proper size and configuration to press the stud out of the hole. Once you have removed the upper control arm, you'll need access to a press to press the ball joint out of the arm. Lacking that, take it to an automotive machine shop and have them press it out for you. Then have them press in the new ball joint.
Old May 21, 2010 | 08:31 PM
Reavenger's Avatar
If you smack the side of the spindle where the ball joint goes through with a hammer and it will pop loose. Then it can be pressed out in place with a ball joint press (basically a heavy duty C-clamp) you can rent from your local parts store.
Moparkyle
Apr 27, 2010 09:24 PM
jellyb30
Feb 17, 2009 02:41 PM
Sherlock
Jan 26, 2009 03:27 AM
01SebringLXI
Apr 4, 2008 09:41 AM
The BIG STEAK
Cirrus & Breeze
Apr 2, 2008 03:08 PM
