Sebring JXi Brake lights not working
Old Sep 28, 2010 | 04:41 PM
mikeg's Avatar
Default Sebring JXi Brake lights not working
Anyone got any thoughts on this -
2000 jxi - none of the break lights work, brake switch has been replaced and confirmed power is getting to the socket the bulb connects to when the brake pedal is pressed - used a circuit tester. Also confirmed power going to the center brake light when the brake pedal is pressed.
Bulbs look fine, part of the element lights up when the lights are on, but the other element does not when the brake is pressed.
Got to be missing something simple ?
Any thoughts greatly appreciated.
Old Sep 28, 2010 | 10:02 PM
If you have power at the socket, but no lights, it has to be the bulb. The two separate filaments are for the two functions of the light, running lights and brake lights. The two filaments are on separate circuits and just because one filament works there is no guarantee that the other one does, too. Since you have a circuit tester you can check the bulbs for continuity. Check both filaments. Check the ground wires as well to make sure the sockets are properly grounded.
It's unusual for both brake lights to go out at once, but what can easily happen is that one side goes out unnoticed, and then the other goes out and you have no lights.
Old Sep 30, 2010 | 08:52 AM
mikeg's Avatar
Excellent - turned out it was the bulbs - all of them. I guess you never check the brake lights until you have to & then it looked like something else !
Lesson learned !
Thanks dcotter0579 !!
4everrunning
Jun 4, 2019 11:30 AM
dmosterd
Jul 15, 2017 02:44 PM
Ericbo101
Jul 16, 2014 10:13 PM
kendude33
Oct 9, 2010 09:09 PM
calpacifica
Aug 26, 2007 04:40 PM
