serpentine belt on 2000 sebring
Old Sep 20, 2009 | 04:21 PM
jimratz's Avatar
Default serpentine belt on 2000 sebring
how do I change a serpentine belt on 2000 sebring
Old Sep 21, 2009 | 03:10 PM
Jack up the car, put it on a solid jackstand and remove the right front wheel. Remove the splash shield (inner fender) by pulling out the push-in fasteners. Now you have access to the belts. Depending on your engine, there are different tensioners, but you should be able to figure it out by looking at it. Relieve the tension and slip off the belt. As long as you are in there, you might as well replace the belt for the power steering pump at the same time.
Old Sep 25, 2009 | 11:56 AM
htran2313's Avatar
Default belt removal
How do i take the Power steering belt off a 2000 Sebring.
i see that the serpetine belt has a tensioner but not the power steering belt. what are the steps to remove the belt. i'm not seeing any bolts to loosen to remove the belt. thanks
yelram
Jul 15, 2014 06:49 AM
fakeplay
Nov 16, 2011 09:51 AM
Baronesa
Aug 22, 2011 11:09 PM
robbiedog
Sep 4, 2007 04:19 PM
donandsandra
Jul 7, 2007 04:17 PM
