Sound Never Heard Of
Old Apr 8, 2008 | 06:25 PM
ryanb4614's Avatar
Default Sound Never Heard Of
1998 Chrysler Sebring Lxi, 113,000miles
And anyone have any idea what the following can be:
WHen i go to a complete stop there is a compress/pulling crank sound, only when car is going then completly stop (at stop sign) maybe when it down shifts?
When i put it into gear same sound... Any ideas, i know its hard to tell without hearing it
Old Apr 8, 2008 | 09:51 PM
bandaide's Avatar
Default RE: Sound Never Heard Of
Almost like a ratcheting sound. If it's what I think it is, you should be able to hear it from just about any of the Chrysler transmissions if you'll stop and listen, maybe on the street corner. If it is this noise, I've been told that it is the tranny solenoids doing their jobs.
Old Apr 8, 2008 | 09:54 PM
ryanb4614's Avatar
Yeah that what it sounds like, I never heard it in any other car like that. Thanks for the reply
Old Apr 9, 2008 | 10:13 AM
irdaneel's Avatar
There is a "clickety-click" chattery sound as the tranny shifts into gear. It lasts about 1 second or less. It happens each and every time you put it into gear. Though I haven't noticed mine on deceleration.
If it's too loud, perhaps a tranny fluid and filter change is in order. That may help.
Old Apr 10, 2008 | 07:19 PM
ryanb4614's Avatar
I have the sound recorded anyone know how or where to post sound files?
Old Apr 13, 2008 | 04:37 PM
ryanb4614's Avatar
http://www.soundupload.com/audio/b9nx3eymlptaltnclick download then open, the car is being put into reverse then drive when hearing the sound...
Old Apr 16, 2008 | 04:04 PM
irdaneel's Avatar
That is a far sharper, more intense sound than it should be, but it has the same characteristics as the "normal" shift sound. Just harder.
Again, fluid and filter change may help. Maybe try a transmission additive before the change. Might just clean things up a bit. That may quiet it down, it may also make it worse. Either way at least you tried.
Old Apr 16, 2008 | 05:25 PM
ryanb4614's Avatar
fluids are good, the dealer told me when i bought it they did the tranny filter and drained
Old Apr 16, 2008 | 05:52 PM
irdaneel's Avatar
FYI... Unless a "Power Flush" was done on the tranny they only exhange about 1/2 of the fluid by draining it. The rest stays in the torque converter, pump, tubes and valving.
It is not likely that the fluid change will help the problem anyway, except for possibly in concert with the cleaning/lubricating additive. This is only a "stab in the dark" that usually doesn't hurt anything. Once in a while you'll clear out an orifice, or free up a sticky check valve etc. Thought you might get lucky.
Chrysler C-bring
Jul 29, 2015 08:08 AM
woodyinbx
Dec 31, 2008 06:28 PM
SportbikeRiderXX
Aug 18, 2008 07:56 AM
meryldean
Jan 16, 2008 01:16 PM
May 22, 2006 02:41 PM
