squealing from engine
Old Aug 11, 2013 | 11:52 PM
revraginsebring's Avatar
Default squealing from engine
Before I replaced the belts turning the steering wheel far left or far right would create a loud squealing noise, now that I replaced the belts I am getting the squealing noise at idle or low RPM, the only way the noise goes away is when I rev up the motor.
Did I need to tighten the belt more, or could something else cause this
Old Aug 12, 2013 | 08:43 AM
The most common cause of squealing is a belt that's not tensioned properly, but it's not the only possibility. Before you do anything else though, make sure the belts are at the correct tension.
Old Jan 7, 2014 | 12:31 PM
estrika's Avatar
i have the same problem (squeal at low rev) i used a stetoscope, and i presume the noise is coming from the alternator pulley.
Old Jan 8, 2014 | 08:49 AM
yes, I just re tighten the belts, helps if you have someone hold the breaker bar while you tighten the bolts
project260
May 5, 2011 04:01 PM
bds0688
Oct 18, 2010 12:45 PM
slyder04
Oct 15, 2010 05:02 PM
amnapoli
Apr 22, 2010 10:56 AM
phatboyfromla
Apr 9, 2009 10:00 PM
