Stalling
Old Jan 20, 2009 | 06:49 PM
tree8588's Avatar
Default Stalling
I've got a 98 Sebring coupe, V-6, that's started stalling when the rpms are low. Any ideas what I'm going to have to fix?
Old Jan 21, 2009 | 09:42 PM
Default RE: Stalling
First place to start is grab any codes from the computer. Malfunctioning engines often leave a trail of error codes that can be read with an OBD II code scanner. Your local AutoZone store might be happy to read yours for you and give you a report.
If that comes up dry, you could look at the idle air control motor for a start, but it could be many other things, too, like weak fuel pressure, or bad spark, failing coil, etc, etc.
Old Jan 22, 2009 | 01:01 PM
Rick99's Avatar
If you go to autozone and they do read the codes, resist any pressure they may put on you to buy the part named in the code. Just post the code up here for more advice.
There's only one guy at our autozone that actually knows anything about fixing cars, the rest of the guys there just pretend they do.
mperkins6
Jun 21, 2006 03:03 PM
Rmason
Feb 4, 2006 05:29 PM
Shadowman
K-Cars
Jan 24, 2006 12:19 AM
Shadowman
Jan 23, 2006 06:18 PM
ChryslerNamedTrixie
Oct 24, 2005 03:52 PM
