START AND STALL HELLLPPPPPPPP!!!!!
Old Apr 27, 2008 | 07:07 PM
sebapeluca's Avatar
Default START AND STALL HELLLPPPPPPPP!!!!!
hi, i have a 96 chrysler sebring 2.4 4 cyl jx. the car wont start unles u press the gas pedal, and when you let the pedal go, it stalls. if you release the pedal very slowly, sometimes it will stay on. please give me detailed instructions if u can asap. Thank you very much
Old Apr 27, 2008 | 07:57 PM
irdaneel's Avatar
Default RE: START AND STALL HELLLPPPPPPPP!!!!!
Likely culprits:
EGR valve, usually a simple replacement.
MAP sensor, usually a simple replacement.
Idle air valve, usually a simple replacement
TPS sensor, usually a simple replacement.
Plugs, wires, cap and rotor, usually a simple replacement.
Start all repairs by conducting a complete inspection of all vacuum hoses, EGR hoses and fittings, electrical connections, etc. Anything that looks bad or worn probably is. Fix those things first.
Most likely, if the car runs well under power, just won't idle, is the EGR valve, then the MAP sensor. After that comes the idle air valve, TPS sensor, then Plugs and Wires.
Other things can cause this, such as the distributor, camshaft position sensor, crankshaft position sensor, O-2 sensors, etc., but the previous list is likely where you'll find the problem.
If it has been a while since a plug and wire change, you may consider moving that up a bit in your list, as they are routine maintainence anyway.
davekro
Oct 17, 2014 06:47 PM
Breezer
Cirrus & Breeze
Apr 16, 2013 12:10 AM
bran1har
Feb 1, 2012 02:37 PM
darkwingduck
Jul 10, 2009 10:20 AM
kruegs55
Cirrus & Breeze
Oct 12, 2008 09:26 PM
