Transmission Noise?
Old Sep 15, 2005 | 03:43 PM
raiderzx24's Avatar
Default Transmission Noise?
Whenever I shift from Parked to Drive I hear a little noise, I was searching and it seems like this noise is common. But I'd figure to post here and make sure.
Old Sep 16, 2005 | 04:56 AM
ChryslerNamedTrixie's Avatar
Default RE: Transmission Noise?
is it a suttle "CLUNK"?
Old Sep 16, 2005 | 08:41 PM
raiderzx24's Avatar
no doesnt sound like a clunk. When I start the car and go from park to reverse sounds like a door creaking. It transfers smooth and everything just sounds weird, but I'm guessing by the research i've had that this is normal im not sure
Old Sep 17, 2005 | 11:26 PM
JXI101's Avatar
it's the solenoid that moves that particular gear I would bet... not much you can do about it... make sure the fluid lines are solid and full... could be an air bubble in the line.. totally common... I wouldn't worry about it... just dont go in reverse with your girlfriend in the car... bad bad bad...
bgeise
Nov 5, 2014 03:38 PM
Mharding
Dec 26, 2008 05:50 PM
nikola
Dec 8, 2008 04:06 PM
sebringpilot
Dec 1, 2006 06:08 PM
MOHAMMEDHU2003
Jul 22, 2005 04:51 AM
