Trunk Light
Old Jan 7, 2009 | 08:49 PM
irdaneel's Avatar
Default Trunk Light
1997 Sebring Coupe. Ok. Looked and looked for the fuse that protects the trunk light circuit. Nothing is labeled, pulled/inspected most lighting or associated fuses and I went through the Autozone wiring diagrams to no avail. Does anyone know which circuit it is on? I replaced the bulb, checked the switch in the trunk latch mechanism, even disconnected the connector to that switch and crossed it manually. No light. No power. Being as though nothing else seems to be not working, I'm guessing I have a wire problem, but knowing which circuit to follow would be helpful.
Old Jan 8, 2009 | 12:46 PM
Default RE: Trunk Light
The circuit for the trunk light, the way I read the wiring digrames in my Haynes manual, is a little weird. It seems that power is sent from the junction block through the light then to the switch in the latch and then to ground. The red/black wire to the bulb should be hot. The red/green should lead to the switch and then to ground when the trunk is open.
Hope that helps.
Old Jan 12, 2009 | 04:10 PM
irdaneel's Avatar
Thanks. I'll run it down under that assumption. A nice place to start.
Old Apr 26, 2013 | 01:06 PM
sdeal5's Avatar
Question
did u ever figure that out.. because i too am haven that same issue
mikertiger
May 25, 2022 04:26 PM
leeb
May 6, 2013 11:17 AM
toyman
Apr 26, 2013 01:02 PM
dark one15
Jun 3, 2007 04:10 PM
boss dog
Jan 15, 2006 11:40 PM
