unusual starting issue 2.5 crd 2002
Old Sep 3, 2011 | 05:25 PM
voyager_dan's Avatar
Default unusual starting issue 2.5 crd 2002
the problem i have is sometimes when starting the car cold/hot the starter will turn and then as if the engine has got stuck which then makes the headlamps come on and various other lights
i checked the earth connections and have fitted a new starter thought i had sorted it with the new starter but today it done it again
next thing i am going to do is change the main feed to the starter and main earth strap
anyone else had similar issues?
dan
Old Sep 11, 2011 | 12:21 PM
right i have put in a new 12v main feed to the starter and earth strap from battery to engine block , thought this may have something to do with it but no it did it again to the wife
what are the possibilites of the new starter being faulty as when i started it the other day it made the grinding gear noise like the gear isnt engaging before turning ?
dan
Old Sep 12, 2011 | 05:13 PM
rodger's Avatar
Hi Dan
Not convinced this is your problem/solution, but it might help.
https://www.chryslerforum.com/forum/...r-motor-14027/
Rodger
Vonhofinvule
12
Sep 30, 2014 07:47 AM
Fress
Nov 19, 2013 03:52 PM
Laimon
Apr 22, 2011 03:35 AM
kyo001
Oct 11, 2010 06:42 PM
huasi87
Apr 8, 2010 08:53 PM
