Why won't my sebring gtc start???
Old May 20, 2017 | 11:58 AM
TLT's Avatar
TLT
Smile Why won't my sebring gtc start???
Mike V.v, Chrysler Mechanic
24770 Satisfied Customers
Pearl Wilson, Chrysler Mechanic's Assistant
Welcome! What's going on with your Chrysler?
You
I own a 2004 Chrysler Sebring GTC. 6 cylinder 2.7 liter R rated engine. My Chrysler Sebring will still not start. I have replace the ECM PCM and the battery. My car still will not start after extensive work being done to the engine. But the only code I keep getting is p1864. It will not give you any other codes but my car still will not start. It will crank but it will not turn over. No signal post for the injectors, no signal pulse for the coils, no signal post for the crank or camshaft sensors. Why are continuity on all wires are good. All grounds are good. All the fuses in modules have been checked in are good. The ASD relay is good. What could possibly be the problem? If my car is not turning over, why am I not getting any more codes? Why is my car not turning over?
Old May 21, 2017 | 12:50 PM
TLT's Avatar
TLT
I had the engine torn down and cleaned out and oil sludge cleaned out, replaced gaskets and Rings, new crank shaft, new rods, new oil pump, new cam sensor and crank sensor, new coils, new boots and new spark plugs, new water pump, new timing chain, replace the oil filter and air filter, and some other things I can't remember. In the prior year I had replaced the ECM PCM and repaired the AC system. Basically my engine was almost completely rebuilt.
What started all this was I was driving and my car turned off on me while I was driving. I was told the fuel pump with functioning and it was getting gas , but that the oil pump was bad and needed to be replaced comment that although there was oil in my car it will have not been getting through to the rods. Then I had all this work done because the crankshaft and a couple rods had gotten bent from lack of oil not getting through to them because oil pump went out. That was the reason I was given that my car turned off on me while I was driving.
all the electrical wires and grounds have been checked and are still good. Although the wiring harness could use replacing everything is still good and the wires all still have conductivity. So I am wondering if the ECM PCM needs to be reflashed? Or is there another problem going on? Everyone is stumped, no one can seem to find a reason why my car will not start. It turns over but it will not turn on.
There is no signal to the crankshaft position sensor, cam sensor, the coils, or the injectors. All the grounds have been checked and are good. All wires were checked and have good continuity.
Everyone is stumped. What could possibly be causing my car not to start??? It does not have an alarm system, and I do not believe it takes a chipped key, but I have the original keys that came with the car when I bought it in 2007 and these kids have always worked with the car before. Please read my above posts & other replies. If it is the ECM PCM again, why does disconnecting the battery and the electrical system from the car blow the ECM PCM? Can the fuel pump still be functioning and still be bad and need to be replaced? The issue is the items listed above are not getting a signal. What could be causing this!? A bad sensor, bad fuses, a bad ECM PCM?
Old May 21, 2017 | 01:50 PM
TLT's Avatar
TLT
Default Additional Information:
The engine was torn down and oil sludge cleaned out, replaced gaskets and rings, new crank shaft, new rods, new oil pump, new cam sensor and crank sensor, new coils, new boots and new spark plugs, new water pump, new timing chain, replace the oil filter and air filter, and some other things I can't remember. In the prior year I replaced the ECM PCM and repaired the AC system. Basically my engine was almost completely rebuilt.
What started all this was the car turned off while I was driving. I was told the fuel pump was functioning and it was getting gas, but that the oil pump was bad and needed to be replaced, that although there was oil in my car, it was not getting through to the rods, which resulted in the crankshaft and a couple rods getting bent from lack of oil not getting through to them from oil pump going out. That was the reason I was given that my car turned off on me while I was driving.
All the electrical wires and grounds have been checked and are good. Although the wiring harness could be replaced, everything is still good and the wires all still have conductivity. So I am wondering if the ECM PCM needs to be reflashed? Or is there another problem going on?
Everyone is stumped, no one can seem to find a reason why my car will not start. It turns over but it will not start. I am hoping someone will have some answers for me in these forums.
It does not have an alarm system, and I do not believe it takes a chipped key, but I have the original keys that came with the car when I bought it in 2007 and these keys have always worked with the car before.
If it is the ECM PCM is bad or blown again, why does disconnecting the battery and the electrical system from the car blow the ECM PCM?
Can the fuel pump still be functioning yet still be bad and need to be replaced?
The issue is my car will crank but will not start, and the crank position sensor, cam position sensor, coils and injectors are not getting a signal.
Please read my other posts & other replies in other forums. Thank you for any help and ideas you might be able to give.
TLT
May 21, 2017 01:48 PM
CoolDaddy
Sep 30, 2016 11:46 AM
CoolDaddy
Sep 25, 2016 08:55 PM
laura
Apr 11, 2010 08:48 PM
scoobygeorge
Nov 23, 2008 07:00 AM
