Won't start after 1 day
Old Nov 29, 2010 | 11:55 AM
blackestate's Avatar
Default Won't start after 1 day
New here, searched but have not found it. I will keep looking, but asking here now.
The car has to crank for a long time after sitting for more than one day, and then it sputters and has issues for the first 10 miles.
this did not happen before I had oil in the valve covers, and changed the gaskets, and also the o-rings on the injectors because I had them out.
I am thinking it is there, But what did I do wrong? or is it in the fuel line to the injector rail?
Seems to me like it is leaking fuel when sitting, but I can not find anything
Old Nov 29, 2010 | 11:56 AM
Should probably say also this is a 97 with the 2.6L
Old Nov 29, 2010 | 12:28 PM
then the issue was created by yourself go look at what U did and see if something is wrong.
Old Nov 29, 2010 | 12:58 PM
I got that part figured out, What I can not find is what I might have done. The o-ring on the injectors look ok, I will replace them again today, and I will replace the hose feeding the injectors also, that one I did not change, and see if it helps.
I am looking for advice on what else to look at when in there, or If there is a secret to one of these fuel items that I did not do correctly.
thanks
6four3
Mar 12, 2019 10:17 PM
Exiled4Now
Other
Dec 1, 2013 09:41 AM
miki75
Dec 16, 2010 07:31 PM
fcms2004
Jan 30, 2008 03:11 PM
Ventura
Sep 13, 2007 07:35 AM
